LG OLED C9 ad a wireless display
I was trying to connect My LG TV as a wireless display, just as on this video:
Unfortunately it works only first time until disconnecting. To reconnect I need to restart TV, sometimes a few times. Sometimes TV is not detectable at all. How it works for you?
5 answers to this question
48 minutes ago, td47 said:
@Janusz Łaski Ensure that your Windows 10 device is at least at OS version 20H1, or better still 20H2. They have improved the casting/projecting software, to make it more reliable.
Thanks for reply. Actually, I'm on 20H2. I am convinced, it is LG WebOS (version 05.00.01) related as I have this issue on few laptops including one with the newest insider win10 version (21XX).
Is it work for you as it should? What is your firmware version?
Posted (edited)
@Janusz Łaski I have an older LG, and also a Foxtel box (soon to get a Fetch box to replace it), so have rarely needed to connect my Laptop. Have done the clunky connecting by HDMI cable before, as my laptop has an HDMI port (for missed episodes not on any catchup services).
I think the latest C9 firmware is now 05.00.03 (they might not document all fixes in the Release Notes) :
[05.00.03]
1. Launcher visibility improvement
2. Launcher exposure when TV is turned on
See here, or search LG site with your actual model number:
Download that to USB stick and install it manually. If that does not fix your issue, you might have to get a "Miracast dongle"! for your TV, if you have a spare HDMI port to use. They are from $11, $40 at Jaycar, $80 for the official Microsoft one.
Edited by td47
typo
@td47 Thank you for hints. I am on newest firmware issued for OLED65C9PLA i.e. 05.00.10 (sorry for typo in OP). I know that there is plenty of options to cast video from my PC.  Here, I am trying to figure out whether my TV's behavior is common or rather I have something messed with my BeOS settings or something.
@Janusz Łaski Ensure that your laptop WiFi is on the same frequency band as the TV (i.e. if the TV is using the 2.4GHz band SSID, connect the laptop to the same SSID, likewise with the 5.0GHz band SSID). Some routers combine the 2 bands under ONE SSID, that makes it difficult.  If you can log into our router, and split the 2 into 2 seperate SSID names, that might help if that is the case.
Also, I heard that having the TV on a LAN cable, and other devices (e.g. Laptop) on WiFi, gives some routers an issue, in that they do not always pass all the required brodacast or negotiation (initialization) packets between WiFi and LAN. This definately affects Apple AirPlay, and maybe AirPlay2 as well, dpenending on your router model, and its security settings, and may well affect casting, screen mirroring, and certain player types and complex sharing apps.
    • By Nick Payne
      We have a 65" G1 OLED set. Lately (like the past couple of months), at irregular intervals while the set is on, it will power itself down without any input from the remote. Happens maybe once every two or three days. Powering it on again using the remote always brings it back to life OK. Unsure whether this is a hardware or software problem, and can't see how I could determine whether it's one or the other. Any suggestions? The TV is current with whatever the lastest level of FW is - I just checked in settings and was told there were no updates available.
      Ballpark Transformed With 11 Digital Signage Displays Including
      Main Videoboard and Ribbon Boards Spanning 842 Square Meters
      SEOUL, April 8, 2025 — LG Electronics (LG) is strengthening its leadership in the global commercial display market by providing state-of-the-art display solutions to Fenway Park, the home of the Boston Red Sox and the oldest ballpark in Major League Baseball (MLB).
      In late March, LG installed a massive main LED videoboard in centerfield at Fenway Park, measuring 30.5 meters wide by 11.5 meters high and covering an area of 350.75 square meters. Additionally, LG delivered a comprehensive display solution comprising 11 digital signage installations. These screens span a combined area of approximately 842 square meters, including a notable 171 square-meter ribbon board display measuring 21.6 meters wide by 7.9 meters high.
      Featuring sophisticated High Dynamic Range technology, LG’s commercial displays strike a meticulous balance between dark and bright elements to deliver exceptionally clear and lifelike imagery. They offer high luminance exceeding 7,000 nits, IP65-rated water and dust resistance, as well as flexible configurations – all tailored to the outdoor conditions of stadium environments.
      Starting April 4 (local time), fans had the opportunity to experience the action of the game in vivid detail, delivered by LG’s LED signage displays during the home opener – the first Fenway Park matchup of the 2025 MLB season between the Boston Red Sox and the St. Louis Cardinals.
      LG’s innovative display solutions are set to lead the transformation of the beloved Massachusetts ballpark, the iconic stadium that has shared in the joys and sorrows of American baseball fans for more than a century since its opening in 1912.
      With a focus on redefining the fan experience, LG has established a strategic partnership with ANC, the agency managing stadium operations and advertising on behalf of Fenway Sports Group, the owner of the Boston Red Sox. Together, they aim to deliver immersive entertainment to sports fans across various regions in the United States, including Boston.
      “This collaboration will elevate the in-venue experience for our fans with cutting-edge technology while also expanding LG’s presence through dynamic activations that will engage Red Sox Nation all season long,” said Troup Parkinson, Chief Marketing & Partnerships Officer for the Boston Red Sox.
      Meanwhile, LG is accelerating its media entertainment platform-based service business, targeting global sports fans by integrating the display businesses – which include TVs, monitors and signage – under its Media Entertainment Solution (MS) Company.
      Earlier this year, LG partnered with AMB Sports and Entertainment to provide displays spanning 141 square meters inside the perimeter of the Mercedes-Benz Stadium in Atlanta, Georgia. LG’s commercial display innovations, including LG MAGNIT and indoor/outdoor LED signage, can also be found at Atomic Golf, a massive entertainment complex in Las Vegas.
      “We are thrilled to be able to strengthen our partnerships with prestigious global sports franchises,” said Park Hyoung-sei, president of the LG MS Company. “We will continue to enhance the value of customer spaces and strive to provide differentiated media entertainment experiences.”
      Ready to elevate your display strategy? Discover how LG’s advanced display solutions can help you create impactful, next-level customer experiences.
      link hidden, please login to view today to find the right solution for your business.  # # #
    • By OliverRC
      Dominating With Over 52.4 Percent Market Share in 2024,
      Company Reinforces Its Unrivaled Leadership in Premium TVs
      SEOUL, March 12, 2025 — LG Electronics (LG) has reaffirmed its dominance in the premium TV market, leading global OLED TV shipments in 2024 with over 52.4 percent of the market share. For 12 consecutive years, LG has commanded the global OLED TV market, continually enhancing the TV experience with audiovisual excellence and AI-powered personalization, embodying the true essence of OLED technology with perfect black levels and enhanced brightness.
      According to market research firm Omdia, LG secured the top spot in the global OLED TV market last year, shipping an impressive 3.18 million OLED TV units. Notably, fourth-quarter shipments alone surpassed 1.1 million units, showcasing the company’s ability to deliver cutting-edge technology that meets evolving consumer preferences.
      OLED TVs accounted for 45 percent of the premium TV market in 2023, based on models priced at USD 1,500 and above, marking an 8.5 percentage point increase from the previous year. With the market expected to exceed 50 percent this year, LG is committed to driving innovation and maintaining its leadership in the OLED TV industry.
      As demand for larger screens continues to rise, the number of ultra-large OLED TV shipments has also increased, comprising 16 percent of the entire OLED TV market. LG remains at the forefront, dominating the market with a 57.5 percent share in 2024 for OLED screens of 75 inches and above, including a compelling selection of 77-inch, 83-inch, 88-inch and 97-inch models.
      Backed by over a decade of OLED innovation, LG is set to introduce its latest OLED TVs, featuring advancements like wireless transmission of audio and visual content up to 4K 144Hz with no latency or loss in quality, AI-powered personalization through webOS, and superior picture quality with enhanced brightness and perfect black levels for a truly exceptional viewing experience.
      Global TV shipments reached 208.8 million units last year, marking a return to growth after three years, with OLED TV shipments rising 8 percent year-on-year to 6.07 million units. Additionally, LG’s total TV shipments across both OLED and LCD models reached 22.6 million units last year, representing 16.1 percent of global TV market revenue.
