App not available on LG store
Dear LG team,
Need some more app on LG store in India, due to lake of this many application are not used on Tv so that customer moved on crome cast or Net DTH box.
we want app on store like MX player,  Sony Liv,  Jio Tv , Jio Cinema, Voot.
and also pls provide update of Zee5. Net speed is perfect but zee5 streaming with buffering so we cannot enjoy buffer free movie or program .
Anand
@ANAND YADUVANSHI This is ONLY an LG TV WebOS enthusiasts peer-to-peer forum, and has NO direct connection or affiliation with LG, the manufacturer, and has NO control or ability to ask or lobby for solutions or fixes.
If you feel strongly about the lack of APPS in your country, raise a support ticket with LG in your country, documenting your concerns and "wish-list".
    • By Ahmad Baeisa
    • By akhil7j
    • By Puja aingh
      Dear LG Team
    • By OKtay Sa
      Hi there,
      i have an 65oled9flb (webos).
      Any one an idea?
      Greets
      Oktay
    • By techguy noob
      My LG TV model number 32LM560BPTC is having an issue where the Sun NXT app is no longer available on the LG Content Store. I was able to watch it before, but starting yesterday, the app disappeared. However, on my other OLED LG TV, the Sun NXT app is still available in the LG Content Store. Is this issue specific to the 32LM560BPTC model TVs?
      Sarath
