  • 11 months later...
Can you please do this asap. I have two LG TVs , one in the living room and the other in my bedroom. My autistic son raises the volume to the full 99 and it's very loud. Can you allow by software update for users to limit their maximum volume please. Sony, Samsung can do it, so you must definitely could do it.
    • By Danilo Peixoto Ferreira
      I wish I could control the volume of my LG TV 65NANO96SNA (webOS 4.50.71) using Apple TV 4K 3rd Generation (tvOS 17.3) with HDMI CEC (Belkin AV10176bt2M-BLK cable). The Apple TV has it on Settings, however, the TV does not respond to it. Turn on/off works. Volume control only works with IR. Could we prepare an update to support and fix it?
    • By RCarlton
      I have a 2 year old LG smart TV and A LG soundbar. Periodically the volume will drop way down and when I turn the TV off and on it restores to regular volume.  TV or soundbar? Any ideas?
    • By PoeyYong Wong
      I have this LG OLEDXXCXPTA TV with Sonos for over 2 years. Except in the beginning where I have some issue with volume control with Sonos, it has been working fine. Recently I am encountering problem controlling volume with LG remote for my Sonos Arc. The only way I could get it back to work is to reset the LG TV to initial setup like what I have done 2 years + ago to regain volume control back with a new setup.
      However this time it seems to be different, I continue to lose volume control unexpectedly and I cannot see a trend. The latest being when I use the Netflix app to watch shows on my LG TV.
      Any suggest to resolve this?
      It is getting frustrating to keep resetting TV to initial setup so that I could use the remote for volume control.
    • By Chris Cawley
      Is it possible to increase the volume of the Bluetooth volume on my TV ?
