Can anyone help? Netflix has suddenly become inresponsive for the last month. Amazon Prime works great, so i know it isn't a problem with my internet connection. I've resorted to resetting the tv to its initial setting FOUR times. I've plugged and unplugged the router countless times (as suggested). It would enter netflix, but eventually go back to error tvq-st-120.
model: UF830T
Country: Philippines
Help, please?
Posted (edited)
@nina san miguel Can you go into yout TV settings to check your firmware version? The latest is 04.26.10 and MAY have fixes for web interfaces that may help Netflix.
See:
and if you do not have that, read how to download it, and put it on to a USB stick (NOT inside a folder on the stick), and install from it.
Edited by td47
typo
Posted (edited)
@nina san miguel As you appear to be on the latest firmware (04.26.10) already, it is NOT worth trying to install the same level again.
Your issue might be something called DNS (it is how the browsers and any internet connection get from your device, to a known site, e.g. Microsoft.com to the actual computer server IP address closest to your area). Sometimes the "default" settings do not work very well, as it may rely on your ISP or router.
So, if you go to your NETWORK settings in your TV, in the DNS part, try putting in 8.8.8.8 (that is the public Google DNS service IP address), and some TV users find this fixes some odd intermittent APP failings, where some work OK, and others have odd issues. Don't forget to select the "save" for the new setting, as some UI (User Interface) windows need this (depends on the TV model), sometimes it is near the bottom, so easy to miss, before you come out of the settings UI/APP.
Edited by td47
clarification
  • Thanks 1
    • By akhil7j
    • By Nicola123
    • By Trung Hiếu Trần
      Specs: LG OLED 55C3
      Router speed: 250mbps
      System: webOS 2.3
      Any ideas on how to fix it?
    • By makem
      I have a  LG OLED55C14LB WebOS TV in the same room as my xubuntu desktop computer and router.
    • By svsrama
      Sriram.
