I set up airplay on our LG smart TV and it works just fine for most things. However, when I try to mirror something from HBO max from the iPad, I get sound on the LG TV but no picture. It’s the same for anything I try to mirror from HBO max, not just a particular show. This is the first time I’ve run across this. Most services mirror just fine. Any ideas? Thanks.
@Gshep1 This may be a copyright (DRM) thing within the HBO App, to stop users "pirating" by streaming to a copying device. I know you only want to "mirror", but maybe HBO have found clever users abusing that function, so have had to block it. If most Airplay or Airplay2 functions are working, then it sounds like you are NOT suffering from the "broadcast discovery" TCP packets issue, where some routers do NOT pass these between LAN connected devices and WiFi connected devices. If your TV is ALREADY on the same WiFi band as the iPAD (i.e. both on the 2.4GHz band, or boeth on the 5GHz band), then it is almost certainly the DRM blocking that is causing the issue. If the TV is on a LAN connected Internet cable, try disconnecting the cable, and enable the WiFi, try it on the same WiFi SSID as the iPAD.
    • By Low Grade
      many thanks in advance😃
    • By NEIL_Auburn
      I have a COMPOSITE signal from a VCR that passes through a DENON AVR to my LG OLED at the composite connector (red, white, yellow) on the TV.
      I think it had displayed video in past use. But now it does not.  TV home shows AV1 connected.  Screen goes BLACK (hint?)  Then if yellow video plug disconnected, MSG from OS shows "NO SIGNAL CHECK INPUTS."
      I think TV thinks a signal is applied when the video cable is plugged in but somehow doesn't display the program!!!
      I have confirmed good video signal on cable direct from devices and from DENON with a portable TV!!
      So, what might be setup up wrong or failed in my OLED TV setup???
      Any help will be appreciated.
         Neil
      Powered by the α8 AI Processor, LG’s Latest QNED TVs Elevate the Home
      Entertainment Experience With Lifelike Picture Quality on Ultra-Large Screens
      SEOUL, Dec. 28, 2023 — LG Electronics (LG) announced the newest lineup of 2024 QNED and QNED Mini LED TVs, offering a wider selection of screen choices including ultra-large 98-inch with vibrant picture quality, advanced AI-powered processing technologies, extensive personalization features and sophisticated design.
      Evolving further, LG 2024 QNED TVs have developed significantly more intelligence with the α8 AI Processor, improving upon its predecessor with a 1.3-fold increase in AI performance, a 2.3-fold enhancement in graphic performance and a processing speed that is 1.6 times faster.
      Leveraging cutting-edge technology for a more refined visual representation, AI Picture Pro offers the ultimate picture quality based on deep learning. This versatile feature adeptly distinguishes faces, objects and backgrounds within a scene, enriching the texture and fine details to present images with unparalleled realism. Dynamic Tone Mapping Pro splits the picture into blocks and analyzes each in real-time to detect the darkest and brightest areas, elevating the details with precise HDR optimization to deliver three-dimensional image quality. With Personalized Picture Wizard, users can effortlessly customize the image quality by simply selecting a few preferred images from a given selection that are intelligently set up through deep learning.
      In addition to vibrant picture quality, AI Sound Pro captivates viewers with the audio excellence of virtual 9.1.2 surround sound from the TVs’ built-in speakers. For a unified audio system, WOW Orchestra seamlessly integrates the LG Sound Bar and the TV’s speakers, resulting in a mesmerizing 3D sound experience.
      Featuring LG’s Quantum Dot and NanoCell color technologies, the company’s latest QNED TVs deliver crisp and vivid picture quality for hyper-realistic viewing. With enhanced color reproduction, the authentic colors of QNED TVs heighten the visual depth for a more immersive and three-dimensional home entertainment experience.
      Achieving realistic contrast, LG QNED Mini LED TVs utilize Precision Dimming technology to improve gradations and accurate backlight control, and LG QNED TVs feature local dimming technology for vivid contrast and exceptional brightness.
      The LG QNED Mini LED TV QNED90 model features Million Grey Scale that differentiates between shades of gray and represents gradation with a 20-bit accuracy, providing immensely vibrant contrast.
      Boasting a sleek and sophisticated design with a slim profile of only 29mm, LG 2024 QNED TVs, including the QNED85 and QNED80 models, blend into any space and add a premium touch to the household. The TVs can also be mounted on the wall, providing greater flexibility for furniture and appliance arrangement.
      LG 2024 QNED TVs also elevate the home entertainment experience with versatile personalization and increased convenience. With the webOS Re:New program,* LG is offering an upgrade to the latest version of its webOS smart TV platform to give more smart TV owners the most up-to-date user experience for the next five years. This notable offer comes to LG QNED Mini LED 8K models launched in 2022 (QNED99 and QNED95 series) and will be extended to additional models in the QNED TV lineup worldwide in the future.
      By utilizing the latest LG webOS smart TV platform, users can create individual profiles to tailor the experience to their preferences. The TVs can differentiate between voices based on the user profiles and offer personalized recommendations by interpreting patterns from their comprehensive usage history.
      Furthermore, the main home UI screen of the newest version of webOS features Dynamic Q Card for fast, effortless access to its services, with customized organization into groups, such as Home Office, Home Hub, Sports and Games. To enjoy users’ favorite digital media, LG 2024 QNED TVs also support Apple AirPlay and Chromecast for enhanced convenience in connectivity and compatibility with mobile devices.
      Enhancing the user experience for individuals with diverse abilities, LG 2024 QNED TVs supplies an array of accessibility features including dedicated menu settings, sign language avatars, remote control tutorials, and guides for quick problem resolution.
      LG’s 2024 QNED TV lineup caters to customers’ diverse needs and preferences with a broad range of screen sizes, led by the ultra-large 98-inch blockbuster, a truly massive screen that will fully immerse viewers with its magnitude. The addition of the giant 98-inch model addresses the growing demand for larger TVs in the premium LCD TV market, and the extensive lineup also provides customers with multiple alternatives that will ideally suit any space, including 43, 50, 55, 65, 75 and 86-inch screens.
      “The LG 2024 LG QNED TV lineup takes the viewing experience to a whole new level with an advanced processor that enables outstanding audio-visual experiences across various screen sizes, while also providing a personalized user experience tailored to each individual’s unique lifestyle and preferences,” said Baik Seon-pill, head of the LG Home Entertainment Company’s Product Planning Division. “We remain committed to delivering an unparalleled customer experience, drawing upon our decade-long expertise with webOS.”
      CES 2024 visitors will have the opportunity to explore LG’s most recent innovations and technologies in home entertainment experiences at the company’s booth (#16008, Las Vegas Convention Center) from January 9-12. To keep up with all of LG’s exciting announcements at CES by following #LGCES2024 on social media.
      * Pop-up notifications offering a full upgrade without the need to select specific UX, UI or features are only sent to customers who have agreed to receive them. Please note that this upgrade does not cover the TV’s hardware performance, features or durability.
    • By Huig
      I have a UJ701V tv from 2017. I get a random disturbance of the sound and picture and then the tv reboots. I have already removed the back cover and everything looks fine. According the logfile i have to replace the mainboard but i think the problem will stay.
      LG is partnering with world-renowned Danish luxury audio company Bang & Olufsen to redefine home cinema.
      link hidden, please login to view, the groundbreaking Micro LED display, and Bang & Olufsen’s flagship speakers combine to present immersive viewing experiences with ultra-large and incredibly lifelike images and powerful, nuanced sound.
      With a sleek, modern design and vivid, ultra-sharp Micro LED picture quality, LG MAGNIT delivers the ultimate in viewing pleasure. Its 136-inch, 4K UHD (3840 x 2160), 120Hz-refresh-rate screen is great for watching movies, TV shows and sporting events – and for admiring artworks – in the privacy of one’s home. By combining the performance of Micro LED with convenient features that enhance content enjoyment, LG has created a unique display for those who demand the very best.
      While the quality and size of images shown on LG MAGNIT are sure to captivate, so too will the display’s elegant, minimalist design. LG’s Micro LED solution for the home has a bezel-less screen for immersive viewing experience, and has a sturdy, stylish aluminum frame with a brushed metal finish that complements any interior décor or color scheme. Likewise, the Media Box, which serves as a controller for LG MAGNIT and shares the display’s luxurious yet understated aesthetic, harmonizes beautifully with the surrounding environment.
      Having produced such a superlative screen, LG tasked itself with finding a sound partner capable of providing an audio solution that could match MAGNIT in terms of design beauty and outstanding performance. Bang & Olufsen – beloved by audiophiles since 1925 – immediately understood LG’s vision for elevating the home cinema experience, and knew exactly which of its superior sound solutions would best complement LG MAGNIT: the distinctive, dynamic Beolab 90.
      Bundled with LG MAGNIT, Bang & Olufsen’s Beolab 90 speakers are the ideal match for LG’s Micro LED innovation in both style and performance. An aesthetic and acoustic masterpiece, Beolab 90 boasts an iconic design featuring curved wooden bases, a series of angular facets covered in sleek fabric, and finishing touches of brushed aluminum. The stunning Beolab 90 sits at the top of Bang & Olufsen’s range of Beolab speakers, all of which are compatible with LG MAGNIT.
      Beolab 90 is a floor-standing speaker that adapts output to the space it is in and the type of audio it is reproducing. With 8,200 watts per speaker, 18 premium drivers, 14 channels of 300-watt ICE power amplifiers and 4 channels of 1,000-watt Class D Heliox amplifiers, Bang & Olufsen’s Beolab 90 makes music and soundtracks come to life in a way that few speakers can.
      Dedicated to delivering outstanding home cinema and user experiences, LG and Bang & Olufsen conducted several rounds of testing to ensure seamless compatibility between the webOS platform installed on LG MAGNIT, and Bang & Olufsen’s software application. Thanks to these efforts, users can now enjoy the convenience of being able to control both LG MAGNIT and Beolab 90 via Bang & Olufsen’s remote controller.
      The LG MAGNIT with Bang & Olufsen’s Beolab 90 speakers is currently on display at international locations. Visitors can experience this pairing at the LG Business Innovation Center in Dubai, UAE, as well as at the Bang & Olufsen store in Riyadh, Saudi Arabia. Moreover, this exceptional combination will also be presented in the Bang & Olufsen showroom in Costa Mesa, California, USA, which is scheduled in September.
