Posted (edited)
@Devanshu Firstly, this is just an LG WebOS user peer-to-peer enthusiast forum, and has NO connection or affiliation or control over what LG do, or might do.
Secondly, the current firmware of  04.06.40 is NOT the WebOS version, ONLY the firmware version, that will have an enterely different WebOS release level related to it, or embedded in it. Th settings -> about TV should show your firmware and WebOS levels seperately, and I suspect your model will be around 3.5.x if you are lucky.
Thirdly, as your TV is a 2015 model, and later WebOS levels are have harware dependencies, you are VERY unlikely to EVER see any updates to the WebOS itself.
Edited by td47
clarification
    • By mean2
    • By OliverRC
    • By Ajothen
    • By Batman
