siddhu Posted March 12, 2021 Posted March 12, 2021 is disney+hotstar app available for LG LF6300 tv web os version is 04.06.40.?? Quote
0 td47 Posted March 13, 2021 Posted March 13, 2021 @siddhu If it is not available in the LG STORE on your TV in your country, then there is no other way to install it. By the way, the "04.06.40" is the FIRMWARE version, and NOT the WebOS version. You most likely have WebOS 2.0 or 2.5.x on that model. Quote
0 siddhu Posted March 15, 2021 Author Posted March 15, 2021 On 3/14/2021 at 4:38 AM, td47 said: @siddhu If it is not available in the LG STORE on your TV in your country, then there is no other way to install it. By the way, the "04.06.40" is the FIRMWARE version, and NOT the WebOS version. You most likely have WebOS 2.0 or 2.5.x on that model. Thank you for the reply. 👍👍😊 Quote
siddhu
