- 1
Update 06.00.05
By Roy Brown
By Tobin
Tobin
By DavidSr
By JRay
By Ajothen
tskrypek
LG 55SJ8500 USA running 05.80.55
Just notified that software update 06.00.05
is available for my tv, presently running
05.80.55.
Has anyone installed this update? How did it go?
I typically wait for 1 to 2 weeks to see if there is any negative feedback.
Terry
Sent from my VS988 using Tapatalk
13 answers to this question
