I have an LG 42LG5800-UG Smart TV but I am unable to locate the LG Content Store
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
Tom M
Today I switched to WOW internet service and dropped ATT and DirectTV. I purchased Sling, but now can't add it to my LG TV because there is no option that I can find to add an APP like Sling. There is no LG Content Store. What do I do?
