My5 loads, won't play programmes
Posted (edited)
@Dartie This might be related to an LG TV firmware update, that is supposed to be fixed in a later one. It is referenced in this article below.
As you have not posted what LG TV model you have, I cannot check what firmware updates are valid or new or have a possible fix for your issue.
A later support article below appears on the Channel5 (MY5) site, that quotes your exact known issue (plays adverts, but no programmes). They do not quote any firmware levels, so it might be best to raise a support call direct to LG in your country to ask when it is being fixed (this site is NOT RUN by LG):
Edited by td47
clarification
    • By JamieG
    • By Bella Lee
    • By Gregor Huc
    • By Abhishek_02x
      I am using the lg tv from 2 years and I found an amazing experience till now.
      But I like request about Play box TV app. Please add this app in store section so that I could download it on my tv.
      It would be helpful if you respond to my email. This app is very demanding now a days as it comes with the excitel broadband service.
    • By keshav iyer
