LG Smart TV 2019: 2 TV's: one is OK, the other one doesn't locate channels (1-999) on Telenet wifi networks
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
mvrvma2
I bought a LG Smart Tv about 2 years ago. Working fine (TV channels Telenet/Proximus, streaming Netflix, Walt Disney+, etc. <i took over a 2nd LG Smart TV from my father-in-law (similar TV). I started using the 2nd TV as well. Strange issue: streaming was OK but WebOS couldn’t find/locate channel stations (region: Flanders part of Belgium). Whatever parameters I use to search channels (frequency, Flanders region, extensions, etc.) the results were always 0 stations. I could only look at the streaming parts (Netflix, Walt Disney +, Flemish stations and so on, including lots of standard apps.
I reinitialized WebOS by using factory default standards but was still impossible to find at least one station of the theoretical 999 available. on Telenet, Proximus frequencies.
Both TV have a Telnet PCMCIA card available replacing partly the Telenet digicorder. Those cards must not be used when searching for channels.
I still don't understand why both TVs are behaving so differently at setup and channel search functions. They are using the same Wi-Fi and are still connected to a coaxial cable. Is it a malfunction, a different setup, some background parameters not cleared?
Any idea, solution very welcome.
Kind regards.
3 answers to this question
