I have a new LG OLEDGX65 TV with a Sonos EARC sound bar but having a problem with connecting a Bernafon hearing aid adapter which requires a optical or RCA output. (
The problem is the optical & analogue outputs are not available when a Sound bar is connected via the HDMI ARC input.  Its possible to connect sound bar using optical but then you loose the control of the sound bar volume(HDMI CEC). Yes you can use the separate APP but that's not a really a viable solution.
So does anybody know of an adapter that can be put on the the HDMI aARC connection to extract the Audio for the hearing aid adapter ?
The ARC sound would also need and be seen by the Sound bar.
  • 2 weeks later...
    • By crct
    • By Justin Bester
    • By hollean
    • By DeeDeee
    • By JamesH
