Hello all,
Sometime I am using my TV as a PC display.
However, the 4 borders of the PC image are missing ( by the same ratio)
I am sure that it is NOT a PC issue, as when using the LiveZoom function, I can 'scroll' to the border of the PC image.
IS there any 'zoom' by default; how can I remove it ?
Thanks in advance for your help...
PS: model is UK6400PLF
  • 2 weeks later...
    • By thewookiewon
      Key Specifications:
    • By Lleuadwen
      Hi, I hope someone can help. I recently bought this TV but can’t find the Art Gallery app that is supposed to be part of the Home Screen.  I have searched in apps but only third party art gallery style apps show. What am I missing here?
    • By Flavio_S
