Disable fireworks screensaver kicking in while watching movie through webbrowser app LG
so i was watching a movie through the webbrowser app of the LGCX65
Every 20 min the screensaver kicks in while there is no reason to as the movie keeps playing
in the background you can even still hear the movie playing
how can i disable this screensaver its very anoying
thanks
Marco
10 answers to this question
@Marco V Some owners have found that if you have a PVR/set-top-box atached to your TV, and they are both using WiFi, and are both active, then the TV can detect a TV programme, BUT without those, viewing via the in-built web-browser only provides a data stream. It seems that the rather "clunky" and feature-sparse WebOS is not smart enough to actually check screen changes for the screen itself, and "assumes" that the image is static .
Other users have found this works:
1. Set Quick Start+ to “Off”
2. Turn your TV off, wait 5 minutes, turn back on
Hi, thanks for answer.
but turning tv off didnt help, i tried.
i dont use the webbrowser functionality often,
most i stream through xbox to tv and then its not a problem
but it’s very weird that the tv has a built in screensaver which cant be turned off by user.
and which cant recognise that the screen is actually changing constantly so no risk of burn in
please lg give update to be able to disable this
when i go away from tv i turn it off anyway(standby)
@Marco V Did you manage to find the "QuickStart+" under the TV settings and turn it off?
By the way: Many owners posting on here seem to think they are posting to an LG owned facility or site forum.  Please be aware that this Forum is ONLY an LG TV Owners and enthusiasts peer-to-peer help forum to exchange ideas and experiences, and advice and possible workarounds by other like-minded enthusiasts. This forum has NO business link or influence over LG, or their product capabilities (or lack of), and does NOT provide any lobbying capability to get things fixed.
Your best action for you (and any other posters on this thread) is to contact LG Support DIRECTLY in your country of use, and register your complaint there, so that they can more accurately gauge the affect of the lack of functionality.
Web Browser updated automatically and started getting the Fireworks screensaver after 20 min of video streaming.
LG Oled65CX PUA, Firmware 03.23.06
webOS version: 5.2.3.29006
tried it all mentioned above with no results. Called tech support and got asked to disable power saving mode and quick start. Still same problem.
As a final resort… I reset the TV to factory default. Lost all my settings but now no longer get the screensaver after 20 min.
I found something that helps, reset TV to factory settings, before that write down your region and backup programs to usb, then after restoring, set region and restore programs, new browser is gone, but every time you run browser it  asks for update and you have to press launch. I found it in a thread and also users suggested to watch movies for free in watchsomuch.tv which was a great site and is fully compatible with WebOS browser. If pay you can watch outstanding 4K qualities on LG OLED
I never accepted the LG_App_Store User Agreement when first opened after factory reset. It does not allow me to go further and be able to search/instal other apps, but my browser newer updated again- which I believe might have been the issue in the first place.
Now, I can continue to use the pause and play buttons on the remote for web streaming (previously disabled by the update) and no longer get the fireworks screen after 20 min.
Terrible sacrifice! Anyway got all my apps on either Apple TV, Google Chromestick or Amazon FireStick.
thanks
Marco
Hi Marco, were you able to resolve this issue? I am having the same problem..and so frustrating. Can you share your solution?
David
    • By mycop
      Greetings.
    • By Charlie F
      Charlie
      Amid the buzz of CES 2025 in Las Vegas, LG’s sweeping semi-circular façade provided one of the most unmissable spectacles of the entire tradeshow as it brought the company’s vision to life with vibrant animated characters. Going beyond its eye-grabbing entrance, the booth embodied this year’s theme of “Life’s Good 24/7 with Affectionate Intelligence,” showcasing how LG’s AI-powered innovations understand and enhance every moment of daily life.’
      The journey through LG’s AI-enhanced day began in the Rise & Shine (LG AI Home) zone. Here, the LG AI Home demonstrated how “Affectionate Intelligence” transforms daily routines for the better. At its core was an advanced on-device AI hub that learns and analyzes lifestyle patterns to deliver personalized solutions without the need for external server connections, enhancing performance and privacy. Visitors explored these AI innovations via an engaging double-sided diorama featuring transparent OLED Signage solutions with detailed miniatures, showcasing how LG’s on-device AI makes mornings more comfortable and efficient by proactively understanding and responding to user needs.
      Visitors could witness this technology in real-life scenarios. For instance, when the system detected someone starting their workday, it automatically created the optimal environment by tailoring the lighting, temperature and humidity of the room to their preferences. With the acquisition of Athom, an industry-leading smart home platform company, LG’s AI seamlessly integrates with over 200 brands and 50,000 devices for limitless scalability and interoperability.
      In the Connect & Cruise (Car-Commercial) zone, LG demonstrated how its AI extends into mobility spaces through the Vision AI Mobility Concept. Visitors experienced LG’s advanced In-Cabin Sensing technology, which recognizes drivers as soon as they enter the vehicle and monitors their comfort, safety and convenience throughout their journey. The system intelligently tracks the driver’s gaze to assess their attention and intentions while simultaneously monitoring their health in real time, illustrating how LG’s AI enables a more personalized and safer mobility experience. In addition, LG’s digital out-of-home (DOOH) platform, installed on the wall to simulate a commercial space, leveraged its AI sensing capabilities enhance visitor interactions.
      The Work & Create (Intelligent Office) zone underscored LG AI’s ability to turn a traditional office into an intelligent workspace. Visitors could see 2025 gram lineup, featuring LG’s first AI-powered laptops – such as the LG gram Pro, LG gram Pro 2-in-1, LG gram and LG gram Book – that smartly adapt to users’ work styles and requirements. Meanwhile, the LG CreateBoard used its advanced AI capabilities to offer efficient document analysis and summary generation, all designed to enhance productivity.
      In the Gear up & Game (Gaming Playground) zone, LG challenged visitors to try out its optimized, AI-powered gaming environment with its webOS smart gaming monitors including the LG UltraGear OLED Bendable Gaming Monitor. The versatile LG ThinQ ON system connects seamlessly with IoT sensors and devices to offer personalized gaming station configurations at the touch of a button. At the center of it all was the new, highly immersive webOS smart gaming monitor with α (Alpha) 9 AI processor, which delivers enhanced 4K visuals and three-dimensional audio through AI Picture Quality Pro and AI Sound Pro.
      The journey continued with a visit to the dynamic Inspire & Innovate (LG Labs Studio) zone, where innovation met practical lifestyle solutions. This unique area showcased LG’s experimental products that cleverly combine various functions to create seamless multi-moment experiences, including the multifunctional LG Projector that’s a projector, light and speaker all in one.
      The zone featured several more ingenious lifestyle solutions like the Indoor Gardening Appliance, the PureDuet coffee purifier and pet-friendly LG AeroCat, as well as the ultra-compact CineBeam S projector and stylish high-up wine cellar.
      Furthermore, the forward-thinking LSM (Lifestyle Solution for Mobility) and PBV (Purpose-Based Vehicle) mobility solution demonstrated the company’s commitment to enhancing daily life through innovative technology.
      LG’s aesthetic reached its peak at the center of the booth, where luxury and intelligent technology achieved perfect harmony in an elegant setting. The centerpiece was the LG SIGNATURE OLED T, the world’s first transparent and true wireless 4K OLED TV, which transformed traditional viewing experiences into the boldest artistic statements.
      The atmosphere was further elevated by a stunning kinetic media façade made of 28 transparent slim OLED screens, synchronized with chandelier lighting to create mesmerizing visuals – from starry galaxies to stained glass patterns. This sublime show of art and technology in harmony demonstrated the true potential of LG’s advanced technology in turning everyday moments into extraordinary experiences.
      Just around the corner, the Curate & Elevate (Upscale Home Living) zone elegantly presented exceptional evening entertainment with the seamless integration of innovative LG TVs into the living space. In a stunning collaboration with iconic design house Kartell, the LG SIGNATURE OLED T could be witnessed in all its glory. This revolutionary display effortlessly transitions from the transparent mode that offers an innovative and beautiful gallery experience to the opaque mode that provides perfect blacks, vibrant colors, and all the advantages that comes with an OLED TV.
      Within the Night area of the zone, LG seamlessly integrated its premium appliances with sophisticated designs. The centerpiece was a second-generation LG SIGNATURE 4-Door French-Door refrigerator with a transparent OLED door panel, standing proudly beside the LG SIGNATURE Smart InstaView Over-the-Range Microwave and Slide-in Double Oven Induction Range, created in collaboration with the premium Italian furniture brand Molteni&C. Also featured were intelligent home solutions, including the LG SIGNATURE Washer & Dryer with AI DD technology and a striking 29-inch matte black washing machine and dryer pair that complemented the Molteni&C dressing room – each element showcasing LG SIGNATURE’s “Live Beyond” philosophy and premium innovations.
      The Escape & Immerse zone invited visitors into a cutting-edge showcase of personalized entertainment powered by the company’s Alpha 11 AI processor and webOS platform. This unique “man cave” featured an expansive 97-inch OLED TV, projection mapping and a “secret door” leading to an immersive LG TV AI world. Guided by a virtual host, tech enthusiasts explored the exciting possibilities of the Alpha 11 and webOS integration, experiencing innovations like the AI-powered Magic Remote, Voice ID technology, cinematic sound and picture quality, and advanced deep learning and soundbar technologies.
      Last but not least, the distinctive Dive & Vibe zone curated a multisensory exploration of AI-powered audio products created in collaboration with multi-platinum musician and tech entrepreneur, will.i.am. The “xboom by will.i.am” line showcased the fusion of technology, AI and musical creativity with its AI capabilities, including AI Sound, AI Lighting and AI Calibration functions, as well as will.i.am’s RAiDiO.FYI platform, which features an AI radio host that customizes infotainment content for each listener. Visitors could experience the LG xboom’s signature sound, professionally tuned with will.i.am, through the new family of Bluetooth speakers – the xboom Stage 301, xboom Bounce and xboom Grab – and the new earbuds, xboom Buds.
      This year’s LG CES booth masterfully illustrated how “Affectionate Intelligence” transforms technology from a mere tool into an intuitive companion, seamlessly integrating AI across every dimension of the human experience – from the home and office to the entertainment and mobility sectors. Stay tuned as LG continues to redefine innovation and enrich daily life, proving once again that Life’s Good.
    • By Kane Murphy
      SEOUL, Dec. 10, 2024 — LG Electronics (LG) has announced a partnership with creative artist, multi-platinum musician, and tech entrepreneur, will.i.am, to launch a new line of audio products under the brand “
      link hidden, please login to view.” The partnership aims to transform xboom into a culture-forward brand with an urban aesthetic, providing an all-new audio experience. In this partnership, LG has appointed will.i.am as LG xboom’s “Experiential Architect.” He will play a pivotal role in carving out a new space for xboom in the audio industry. Drawing inspiration from his pop culture and technological know-how, will.i.am will provide strategic counsel for LG xboom’s product development, design and brand marketing. By combining LG’s advanced technologies with will.i.am’s unique insights as a world-renowned music artist and tech entrepreneur, this partnership will infuse LG xboom products with fresh creative aspirations.
      “Working with renowned tech and lifestyle innovator, LG, opens the door to groundbreaking and dynamic experiences that speak to a broader community of music enthusiasts,” said will.i.am. “By bringing our cutting-edge technology and distinctive creative visions together with LG xboom, we want to foster an iconic culture where people can explore their passion for music with others on a whole new level.”
      The 2025 line of “xboom by will.i.am” products, including Bluetooth speakers and wireless earbuds will be unveiled at CES 2025. The xboom Buds will be the first product available in the market.
      All “xboom by will.i.am” products bear the mark of will.i.am, who took part in creating LG xboom’s signature sound that boasts a rich bass with a balanced and warm tones. It comes in two distinct modes for listening: one mode provides stimulating sounds that gets you moving with powerful bass while a second mode offers a soothing sound with harmonious tones. The overarching design for LG xboom aims to elevate music enjoyment. Speakers incorporate clever embellishments such as easy-to-hold straps and colorfully interactive lighting that is in sync with the beat of the music being played. Earbuds are designed ergonomically with ear tips and ear hooks for a comfortable fit that also delivers the best sound experience.
      “This launch marks the integration of our wireless earbuds and Bluetooth speakers into one audio brand, LG xboom,” said Lee Jeong-seok, head of LG Media Entertainment Solution Company’s audio business division. “We are thrilled to announce this partnership with will.i.am that will play a critical role in solidifying LG xboom’s new identity.”
      All “xboom by will.i.am” products will be integrated with will.i.am’s RAiDiO.FYI, an AI-powered interactive audio experience, to introduce a new generation of listeners to infotainment. RAiDiO.FYI empowers listeners with unique abilities to immerse, personalize and have a two-way real-time conversation with their favorite topic-based STAiTiONS. This conversational media platform transforms radio as we know it into a new dimension, connecting consumers deeper with the music, talk radio and cultural content they love.
      LG and will.i.am will celebrate this new partnership with product showcases and tech demonstrations at CES 2025 (January 7-10). To know more about “xboom by will.i.am”, please visit .
