Getting ARC HDMI to work permanently with Arcam SA30
By Venkata
Hello Team,
By OliverRC
By Horniak
By CJ Catalano
Derekc
I am trying to get the HDMI ARC to work from LG OLED55B6V to Arcam SA30.
I can do this by removing all other HDMI cables from the TV and then configuring to work. This is OK for some time, but then going back to it means going through the whole process again.
Does anyone know of a way to set this up permanently?
6 answers to this question
