Apps pop up along bottom of screen when switching TV on
By Batman
Serial Number:- 309MAUAGGP74
Programme Mode:- Antenna
Software Version:- 23.21.30
By AmuLulu
By Pranay Mokida
By MNHL
By Tobin
Tobin
CJW
I have an SM9010PLA just over a year old. Since a month or so ago whenever the TV is switched on all the apps pop up along the bottom of the screen as if I've pressed the home button. They stay there for about 30 seconds unless I select TV or point the pointer to the screen and click. I thought it might be a system upgrade problem and I've since checked if there are any further upgrades and there aren't. I reset the TV to factory settings which said it would also delete all the apps I had installed - which it didn't.
Anyone else had this and/or know a solution.
3 answers to this question
