. With Tunelf Spotibeat Music Converter, you can and then transfer them to LG webOS Smartwatch for playing without limits.
  • 3 months later...
Thanks. To play Spotify music on LG webOS smartwatch, I use the
. By using this tool, I can easily get Spotify songs as local files and then I can move them to the watch for listening. By the way, this tool now can be bought with a large discount at . You can go to the webpage and check it out.
Thanks for the tips. I agree with you that we need to download or
in advance. I use another to do that and  transfer Spotify music to my LG smartwatch. The conversion speed is amazing.
  • 2 months later...
Posted (edited)
Thanks for sharing. I have a Spotify music converter and I had used it to download Spotify songs to MP3 for use on LG Smart TV. It is the tool from  AudFun, which is great and easy to use. With it, I can enjoy Spotify music anywhere and anytime.
Edited by Alex
Links removed
  • 10 months later...
If you want to play Spotify Music on your LG webOS smartwatch, you need the help of a professional
. It downloads and converts Spotify Music to a common audio format so that Spotify Music can be played offline on a variety of devices, including the LG webOS smartwatch. This way, you can enjoy Spotify Music directly on your LG webOS smartwatch even if you don't have an internet connection or the Spotify app.
  • 2 years later...
It looks like Spotify doesn’t directly support the LG webOS smartwatch right now. To listen to Spotify music, you’ll need to download and convert the songs to MP3 first. Tools like Tunelf Spotibeat or other Spotify converters can help you do this, then you can transfer the music to your smartwatch for offline listening.
  • 1 month later...
I used this some time ago, and it’s very useful.
