bluetooth surround sound/internal speakers
By JamesH
By Fredrik Andersson
By ato53
I have a new C4 TV.
Thanks for the follow-up
By Kane Murphy
By janisad
I have an LG 32LJ610V TV.
tiadenif
I have paired bluetooth headphones with my lg smart tv using bluetooth surround sound/internal speakers. It worked except the volume control for the
tv overrides the volume on the headphones. Is there a way to get the headphone volume to work making them louder while leaving the internal speakers as they are set? Thank you
