UM7500PTA can't select internal subtitles in MKV files since 5.00.15 update (there is a workaround though)
Hi all - have an UM7500PTA TV and steaming movies from my Synology NAS's DLNA server. (mkv HDR 2160p movies mostly)
SRT embedded subtitles had not been a problem and could select any of the SRT subtitle tracks, but not since 5.00.15 update.
I found a workaround though: if I add a dummy external srt file with one single subtitle inside, I can select internal subtitles and then the "track" button will be active to select any embedded srt sub.
Was looking into firmware downgrade via LgDTVUpDater, but not sure if a 2019 model TV can be downgraded that way.
Any ideas - thank you.
    • By MURAD
    • By JohnoFon
    • By starwoodtech
    • By dzoole
      Silly question by me, but it seems that I can't find subtitle button on LG ThinQ app on my mobile phone? Anyone knows if we can select subtitles through the LG ThinQ app?
    • By BGee
      On my LG 60SJ850T, Watching Horizon from AppleTV streaming service. Western with some scenes with Apache language being spoken. No subtitles appearing. When CC is on, see “foreign language being spoken”. When viewed on iPhone, there are subtitles. Have tried same movie using chrome cast TV, and casting from iPhone to Apple TV device. Never get subtitles. Verified subtitles work when I stream to same chromecast TV connected to a different TV.
      reset LG TV to factory settings after trying all available CC and subtitle settings on TV. Still no subtitles.
