Hello Team,
Debug mode is not opening only, please help me, how to resolve this problem.
While I debug the application, I'm getting the error and I have mentioned the same in below.
21/04/21 10:09:50 am : [Launch] Application Debugging - http://localhost:40251/devtools/devtools.html?experiments=true&ws=localhost:40251/devtools/page/24C9FDB6-F555-BF50-69F2-AB28FCF5071D
21/04/21 10:09:50 am: [Launch] ares-launch ERR! uncaughtException TypeError: Bad argument
21/04/21 10:09:51 am : [Launch] Caught exception: TypeError: Bad argument
  • 2 years later...
On 4/21/2021 at 11:08 AM, KARUPPASAMY KANNAN said:
Hello Team,
I'm also facing same issue... Please tell me how to rectify the issue...
    • By atcronin
