Turned off the screen. Now, how i turn it on?
6 answers to this question
@mogoan What LG model is it, and how did you manage to do that? Is the sound coming from the TV speakers, or an external AMP or Receiver? Are you using an external TV box, PVR,  Foxtel, Sky, Fecth box? What happens if you press the Home button on the remote? Have you turned off the TV and unplugged it for a few minutes (standby might not be enough to reset it from "odd" issues)?
    • By crct
    • By DWINKS49
    • By Batman
    • By u84six
