@peter shaky 73 It would be usful to know the LG TV model.
When you state "my fibre optic cable is allowing my devices onto the WiFi" I assume you are talking about your Home Router, that will create and control your WiFi environment? These are usually connected to your Fibre (FTTH) modem via the WAN port on your router, using a standard Ethernet Cable.
Do you by any chance have an Ethernet (LAN) cable connected to the TV? Has WiFi ever worked on this TV? Has anything changed?
    • By RJ Fischer
    • By Regis Wheeler
    • By JasonB
    • By AMK
      Tv model 55UJ630V-TA
      Sw version 06.10.50
    • By Tunari
