The changing of the seasons is a great time to refresh and revitalize your home with a seasonal reset. Cleaning your dwelling from top to bottom may never be fun, but it can be done smarter and easier with the help of the LG ThinQ app.
1. Lighten your load
Thanks to the ThinQ app’s Routine feature, you can apply customized settings to all connected appliances in the house in one step. Select Fresh Air Mode, for example, and the air purifier starts up, the robot vacuum begins roaming and the ceiling fan starts spinning. Now with LG’s smart appliances doing their part to lighten the load, it’s time to get cleaning!
2. Take breaks in between
With the ThinQ app and LG’s smart appliances, you have more me time because you won’t have to constantly check on the progress. You’ll never have to run back and forth checking on the laundry because the ThinQ app can tell you exactly how much time is left and send you a notification when your sheets and pillowcases are clean or dry. With ThinQ by your side (or in your pocket), you can afford to sit back, relax and enjoy the new season.
 3. Your personal technician
Don’t let a glitch in your appliance put everything on hold. With the ThinQ app’s Smart Diagnosis and Proactive Customer Care, you can identify and resolve issues without having to call or wait for a customer service representative or repair technician.1 The ThinQ app even informs you when you’ve put too much detergent in the washing machine and when to change the water filter in the refrigerator.
4. Go green
When you’re taking care of your home, also think about taking care of your planet. With the ThinQ app’s Energy Dashboard, you can easily monitor how much energy every LG smart appliance is consuming so you can adjust settings accordingly to save electricity. LG’s eco-conscious appliances help reduce your home’s carbon footprint thanks to their efficient use of energy and water.
5. Replenish and reorder effortlessly
When it comes to keeping LG appliances running their very best, there’s no need to head to the store with ThinQ. For consumables such as detergent and filters, use the Store feature on the ThinQ app and have them delivered right to your front door. You can also take advantage of Amazon smart reorders by linking the ThinQ app with Alexa. Once connected, you can receive notifications when it’s time to replenish essential items such as laundry detergent to easily reorder from Amazon using voice commands.2
With the ThinQ app from LG, undertaking a residential reset for the new season is a much smarter and simpler affair. Learn more about LG’s smart appliances and the ThinQ app at
1 PCC available in the North America and Europe.
2 Amazon smart reorders available only in Germany, UK and US. Products available for smart reorder differ by country.
    • By anna groove
    • By David Daul
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By Flowace
      How do you measure your productivity? Are there specific metrics you use?
      Home is where the heart is, and it’s also often the best place to start when you’re seeking to make a positive difference in the world. A prime example is the ‘home electrification’ trend, which, in a nutshell, helps drive sustainability by replacing fossil fuel-powered household appliances with cleaner and more efficient electricity-driven ones.
      Home electrification includes the installation of electric appliances and heating and cooling systems, such as heat pumps, which transfer heat from one place to another by circulating refrigerant. Heat pumps provide the practical benefits of year-round indoor comfort and lower utility bills. When integrated with solar panels and battery storage systems, they take things a step further – empowering homeowners with energy independence and the ability to power their homes during outages.
      According to a study published in the peer-reviewed scientific journal Joule, electrification could reduce greenhouse gas (GHG) emissions in the residential sector by 36 to 64 percent and cut overall GHG emissions in the U.S. by 5 to 9 percent.1 To accelerate the transition to electrification, many governments are now offering incentives and subsidies, such as those included in the U.S. government’s Inflation Reduction Act, to encourage the adoption of energy-efficient home technologies.2
      Electrifying your home with LG brings the compelling advantages of the company’s industry-leading core-tech and extensive lineup of sophisticated, energy-efficient products. LG’s innovative core components, including reliable, high-efficiency motors, ensure unparalleled performance and energy-savings across a variety of home appliances.
      The company also provides the seamless connectivity and easy energy management with ThinQ Energy, compatible with a comprehensive range of LG appliances and HVAC systems. The LG Home Energy Platform, centering on the Energy Storage System (ESS), optimizes energy usage to prevent waste and emissions, and enables smart control of connected home appliances.
      Many of LG’s products, which help reduce carbon emissions and enhance energy efficiency, are eligible for rebates. From ENERGY STAR® certified induction cooktops to low energy-consumption, low-emissions HVAC systems, LG offers a diverse array of cutting-edge solutions that can drastically decrease household reliance on fossil fuels and boost efficiency at the same time. Among these are water heaters equipped with heat pumps, and innovative laundry solutions like the impressive WashCombo washer-dryer with Inverter HeatPump.
      Embracing home electrification is an investment in a cleaner, healthier future. With LG’s energy-efficient appliances and core technologies, you can transform your living space into an all-electric abode – shrinking your energy footprint, minimizing your environmental impact and making a positive difference in the world.
      To learn more about LG’s solutions with energy efficiency for home electrification, stay tuned to
      link hidden, please login to view and . # # #
