    • By Francis torres
      Greetings good how can I install android applications on my tv and I need help with the soware for Latin America of my 49UK6400PLF
    • By JetForce
      Dear All,
      I'm new here hoping to find a solution to my problem, after now trying around for almost two days without any result.
      My set-up:
      - LG OLED55C97LA OLED TV
      - Nubert nuPro X-3000 (Pair of active speakers)
      The active speakers are connected to the TV via HDMI-ARC on both sides. I'm aware that my configuration might be a bit unique, however I have the feeling that it is the TV / webOS which is messing arround with me.
      After connecting my speakers to the HDMI-ARC, changing the TVs output to the HDMI 2 (ARC) is started the device configuration. I was glad, as typing in "Nubert" into the device selection of both "Home cinema system" or "Bluetooth / Soundbar", the webOS brought up a configuration to select.
      During the "try-out" phase of the configuration process, turn on and off the power of the speakers works perfectly - even very fast! After configuration, sound comes through the speakers very well and I can adjust the volume. However, when I turn of the TV the speakers will remain on. Same vice versa when trying to turn everything on by only starting the TV.
      Does anyone face a similar problem and might have a workaround for this? It is very frustrating and annoying, as it works perfectly in the configuration - but not later on.
      Thanks for your help!
      Sebastian
    • By xcube
      I share audiovisual material (movies and series) with my brother who has an LG 49UK6400PLF and it has us crazy, because some subtitles do reproduce them and others do not. I have already tried internal and external subs and various formats, srt, ass, ssa, sub, and nothing, because some work and others do not.
      I would like to know at least the reason, to try to solve the matter.
      Regards.
    • By Ian Augusto Jacques Harbs
      Today app should have some kind of configuration, where you can choose which video apps suggestions appear.
      Like, only netflix suggestions, netflix and hulu, and so on...
      Sorry about my poor English.
