By
pivotCE
link hidden, please login to view.
Stuff You’ll Need
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
The post first appeared on .
Related posts:
Paul1111111
I updated to webos 05.60.15 recently and now a mini guide incessantly pops up every time I change the channel. It's there any way to stop this or opt out of the mini guide coming up all the time?
4 answers to this question
