Settings Lost
By Cody94549
By Low Grade
many thanks in advance😃
By Magsing
By Itachi3431
Hi all,
P.S., running latest Web OS
By PoeyYong Wong
I have this LG OLEDXXCXPTA TV with Sonos for over 2 years. Except in the beginning where I have some issue with volume control with Sonos, it has been working fine. Recently I am encountering problem controlling volume with LG remote for my Sonos Arc. The only way I could get it back to work is to reset the LG TV to initial setup like what I have done 2 years + ago to regain volume control back with a new setup.
However this time it seems to be different, I continue to lose volume control unexpectedly and I cannot see a trend. The latest being when I use the Netflix app to watch shows on my LG TV.
Any suggest to resolve this?
It is getting frustrating to keep resetting TV to initial setup so that I could use the remote for volume control.
Soloman
LG 55SM80850PLC TV set repeatedly forgets, corrupts, deletes or otherwise renders useless any "Quick Select" and also "Scheduled" settings. These facilities are not fit for purpose.
