- 1
LG 55EC930V update web os to have Apple TV
By Roy Brown
By Tobin
Tobin
By DavidSr
By ato53
I have a new C4 TV.
Thanks for the follow-up
By JRay
Luis Miguel Caston
Dear all,
Trust you are doing well.
Do you know if is there a possibility to update web os version¿
I have 1.4.0 web os version and doesn’t have the app: Apple TV
Thank you for your support.
