error in date & time Smart TV
By PVD
By Will M
By Lesbo
- 0 replies
- 2,098 views
- 2,745 views
- 4 answers
- 4,394 views
- 2 answers
- 2,760 views
Hassan Al-araishy
Hi....
The date and time return into the default (year = 2014) when i turn TV OFF and ON again,
Which is why the Internet does not work on YouTube , and error message appears cleared
How can i solve the problem
Device : LG smart 3D TV 42"
