Recently bought 32LG 6370 and struggling with recording. Installed USB hard driver and recordings working on that but how do you record more than 1 program at a time and also watch another channel and pause live TV?
    • By JamieG
    • By SergeNault
      Hello all, quick question,
      I have an LG Smart TV, with the latest firmware ( 04.50.56), that is connected to a PVR ( Cisco).  That PVR, via a cable company called Videotron,  has about 50 of exercise videos of 20 minutes recorded over that past years.  I wish to move away from my existing TV provider, but before doing so, I'm trying to figure out how to export the videos into an external drive ( USB, cloud) , so that I can re-use them. Some people have suggested to remove the hard drive from the PVR and export to a USB, but those files are encrypted.  So outside of using my Iphone and actually record the shows, is there a better quality way of doiing it?  I'm thinking some sort of app, that the TV can download, and then record to a USB drive for example.  Thanks for sharing any positive outcome.
      Serge
    • By Batman
      I have a LG 43QNED756RA AEK Smart TV
      If I go to General -> Programmes -> Programme Manager -> Edit All Programmes, I only get the options to Lock/Unlock and Skip/Restore
      So I cannot Move or Edit Program Numbers or Delete
      Any help and comments would be appreciated
    • By Richard Fitz
      I have just purchased a Seagate 2tb Hdd to record on my lg tv it is recognised on the dashboard but when I try to recorded it asks me to insert a drive. Any sugestions
    • By Di59
      I have 2 LG smart Tv's and I am unable to pause live TV with my 40Gb USB which I have formatted to NTFS.
      TV models
      43UJ634V
      And
      32LM6300PLA
      Please can you give me easy to follow instructions so that I can set up both Tv's to be able to pause live Tv and to be able to record programmes.
