Recording starts one hour too late
Recent  recordings - planned from program guide - started one hour too late. My guess: Problem might be connected to summer time (Germany, CES) as it used to work correctly beforehand.
Times shown in program guide are correct CES.
Has anyone an idea what to do? Thanks
Horst
    • By Charlie F
      Charlie
    • By Hoghton Jim
      Many thanks.
    • By StefanosBand
    • By Kev999
      I can only get the Reminder facility to work on live TV in the lower channels like 1, 2, 3 etc, but rejects attempts to use with the HD channels at 101, 102 etc.   Is this normal?
    • By Nooneuno
      Our tv always needs to have the recording volume reset... the problem seems to be that the formatted disk has a small boot partition, about 150 mb, plus a 4 GB "main" volume, and the recording app "sees' the boot partition, and won't "hold" the setting for the main volume...
