Files download not supported
I have an Model # 65UN7300AUD Serial# 003RMXX20818.  I cannot download   a nything it says File download not supported.   It will not let me  open attachments or files that are  sent to my email.   Please help!!   If you need further info you can call me at 705-223-3723  my name  is Jo-Anne Poitras  I purchased the LGTV on October 2020.
    • By Evelynn
    • By matesz
    • By mahdi alborzi
      I need to update this TV
      Model : 55SJ850V-TA
      Serial number : 707CGKWMJ215
      ESN : LGTV20171=11001816919
      VSN : 1F580793
      Widevine: LGTV17CLGE002389488
    • By mahdialborzi
      از درگاه وای فای بروزرسانی نمی‌شود پس نساز به فایل برای بروزرسانی با فلش مموری کارت دارم.
      لطفا کمکم کن ید
    • By dolbnya
