- 1
WiFi not working on Software Version 06.00.15
By Roy Brown
By Rex G
By sudar shan
By NaveenKumar
Latest version of sun NXT app version 8.0.20 is not working for web os Tv version 4.4.2-11 plz do the needful full & Airtel Xstream is not found in your web os platform kindly check on that too
puma99dk
I got 2 LG smart TV's running Software Version 06.00.15 and after this update WiFi has stopped working and the WiFi in both TV's will only stay connected when I am in All settings-->Network-->Wi-Fi Connection and the TV's are also feeling really slow in the menu but the moment I plug in a ethernet cable and disable WiFi everything works and the menu is smooth so I believe there is something up with this software version.
I have a iPhone 12 Pro Max, Laptop and some other devices on WiFi no issues at all.
The TV in the living room is a LG 49UJ701V the one in my bed room is a LG 55UK6100PLB.
Anyone got a suggestion I can try? I do not want to reset them because I do not want to calibrate them both again it's a pain.
9 answers to this question
