Software update 06.00.15 issue
I have 43UJ701V smart tv, working fine for over 3 years.  Recently the software auto updated to version 06.00.15.  Since then if i run an app such as ALL4 or say ITVHUB the adverts within the programs freeze for a few seconds repeatedly untill advert complete and program starts. All apps are upto date.  Any suggestions?
4 answers to this question
Are you using Wi-Fi¿
If so try Ethernet cable instead because this software version has made Wi-Fi useless in my 49UJ701V.
I wish LG would test their shit out before releasing it but I guess that's too much to ask for plus if I disable Wi-Fi and use Ethernet the menu feels more snappy.
    • By mean2
    • By OliverRC
    • By Ajothen
    • By Batman
