HP's announcement:
HP also announced it is releasing version 2.0 of webOS’s innovative developer tool, Enyo. Enyo 2.0 enables developers to write a single application that works across mobile devices and desktop web browsers, from the webOS, iOS and Android platforms to the Internet Explorer and Firefox browsers – and more. The source code for Enyo is available today, giving the open source community immediate access to the acclaimed application framework for webOS.
  • 1 year later...
    • By NaveenKumar
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By Steve D B
    • By Ali Zia
    • By 43UR81006LJ
