How can I Block the settings function?
By Cody94549
By Low Grade
many thanks in advance😃
By mortel
Hello
Modele : TV LG OLED65C15LA
Firmware : 03.41.00
WebOS : 6.4.0-21
i'm french , i can't deactivate function "TV Rating Lock" , access by General > System > Safety
(i change language form french to english before photo)
i see on video it possible
By Magsing
David Sparks
How do I Block the settings function on LG 65UN6950ZUA ?
