HDMI PLAYSTATION RECORDING
By Venkata
Hello Team,
By OliverRC
By hollean
By Hoghton Jim
Many thanks.
By Kane Murphy
- 3 answers
- 538 views
- 1 answer
- 1,569 views
- 2,135 views
- 8 answers
- 6,717 views
reshmamary
I am using playstation in HDMI port I wanna to recirds the game which I play.. is that possible. If yes pls ping me the solution
