Firmware lg nano 916NA - 3.21.90
By SHawk
By Sqwazy
By majorusa
- 3.23.24 - Romania- 47LB730v
By сергей фролов
By SailorMoon
- 0 replies
- 608 views
- 1 reply
- 266 views
- 4 answers
- 1,228 views
- 1,223 views
Vetald
what's new for tv in this update? Does it need to be installed or will it degrade the software capabilities of the TV?
