    • By u84six
    • By Speedemon
      I have a UK6300 LG TV. It has always worked faultlessly. However it now will not show the pointer unless I restart it and then it only there of only for 20 seconds and then it is gone. The LAN cable notification constantly disconnects and reconnects. The Web Browser no longer opens on my selected page. The Software version is the latest and when I tried to manually update the software in case the auto update got corrupted it will not recognize the USB drive as having the software on it. The software browser version is 05.50.15.
      Any ideas what to do. I have two other LG TV's and all work perfectly.
    • By duckie133
      VERY ANNOYING!!!!!!!!!!
    • By Smartboy
      Before I buy this very nice LG TV with WebOS 23, my wife and I were using an old samsung with an android TV box. So it is very difficult to adapt to the cursor / pointer. I read the documentation and found it is possible to press the direction buttons to momentarely remove the cursor (which is painfull to navigate for us). But each time I press one of the home, return, wheel buttons,  then you know what, the pointer is back on the screen. I read the documentation from A to Z and didn't find any parameter to permanently DISABLE the pointer ... Any workaround or parameter that I missed ?
    • By Packard8
      Hi Folks, I recently bought an LG 65C3 OLED. When first set up, the on screen pointer was visible, now it has disappeared. Under setings>pointer options are grayed out (deactivated). Is there a way to recover it short of resetting everything to the default state? Thanks
