Just bought a new 65 inch freeview/freesat LG TV
Lovely...   mmm
No All 4.  No My 5   No STV Player    Can these be loaded any other way ?  Why can't LG put them in their store?
No record as TV doesn't have a memory drive preloaded despite it claiming could record
Nightmare navigation on web with remote.  Can a mouse be used instead.?
    • By Jack1151
    • By wallyricks
    • By MNHL
    • By Nishant singh
      Hi Team
    • By Matt Moran
      Matt
