Can I transport a car from an auto auction?
By Venkata
Hello Team,
By Pranay Mokida
By Flavio_S
By Extra Celestial
Would love to auto start the Alexa app so my smart home can connect to it automatically when I turn it on from a plug since you can't turn on the tv with the hubs.
One small workaround instead of trying to figure out how to turn on the tv from a hub since it disconnects from the wifi when it powers off.
