And yet another bug in the webOS browser update
The bowser no longer displays PDF files.  Several online PDF files that were bookmarked in the previous browser version won't open now.  This version just says "downloads not allowed".  But I don't want to download (and save), I just want to open and display them.  The previous version had no problem with this.
So far. this newest browser seems to be a major downgrade...
Does anyone have a workaround for this, or any of the other problems I mentioned before?
New browser has several issues, I had subtitle issue and I found something that helps, reset TV to factory settings, before that write down your region and backup programs to usb, then after restoring, set region and restore programs, new browser is gone, but every time you run browser it  asks for update and you have to press launch. I found it in a thread and also users suggested to watch movies for free in watchsomuch.tv which was a great site and is fully compatible with WebOS browser. If pay you can watch outstanding 4K qualities on LG OLED
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Jaswinder Sandhu
