6 hours ago, nhk said:
Latest firmware fixed the Dolby Vision. I’ve turned off auto update.
I waited until the firmware was available OTA rather than using the USB stick method.
Which version bro?
Issue continues to persist for me. Temporarily plugged my Shield directly into my C9 instead of the receiver which avoids the problem.
According to Vincent Teoh we can expect another update for this issue:
On 7/11/2021 at 2:35 AM, Garden said:
Which version bro?
05.10.15
My setup is ATV > Denon 2600H > LG C9 (65 inch).
did the OTA update and Dolby Vision is working fine.
Iam having the same issues with the LG C9 when using Dolby Vision on HBO Max through a Chromecast. I also have a Bose soundbar. I decided to try and watch Dolby Vision without the soundbar as the sound option and it worked flawlessly.
As a workaround, I then changed the audio back to the soundbar and I'm still having no issues. Annoying but at least a temporary workaround
  • 5 weeks later...
1 hour ago, legends92 said:
Firmware v05.10.25 was just released in South Korea and for ATSC models. I haven’t tried it yet. Hoping this release resolves all DV issues.
You can download it - see AVS Forum Post:
I'm nervous as I'm getting used to plugging my Shield into the C9 rather than my AVR. I don't want things to get worse. I'll wait for others to install it first and provide feedback.
