LG OLED65B9SLA low ethernet speed 15-20mbps download, upload 25mbps (ISP 300/25mbps)
By Trung Hiếu Trần
Specs: LG OLED 55C3
Router speed: 250mbps
System: webOS 2.3
Any ideas on how to fix it?
By glendvd100
Hi there, I have the following tvs:
OLED55C26LD
OLED42C24LA
And I'm trying to change the area code using the service remote, so I can download apps from USA (I'm currently in the UK), such as Max, HULU etc. I'm trying the codes which are bandied around the internet, but the area just stays as EU. I've noticed on youtube videos etc that the older models with the older OS have no issued with this, but mine seems unable to change.
Does anyone know if perhaps the newer models have newer codes? I've used 1793, 1843 and 22287 (as found in this very forum). But nothing happens. Any help from users who may have got this working would be appreciated, thank you.
By Musica napoli live e anteprime
Hi, I would like to know if it is possible to exceed a speed of 100 mb/s with an Ethernet adapter for LG webos 3.5 TV and if so which adapter? I tried the one from Cable Matters but nothing
By EuphemiaIolanthe
MovieBox Pro APK is an app that provides access to millions of free movies and TV shows. It aggregates the largest collection of popular titles on the internet. Moreover, users will be able to watch unlimited streams. The app allows users to share videos on social networking sites and has a lot of features to keep its users entertained.
MovieBox Pro APK is compatible with both Android and iOS devices. Its home screen provides information such as top new releases, hot TV shows, and the latest movies and TV series. It also provides movies based on their IMDB rating. You can also find popular movies based on genre such as comedy or romance.
The app also features a search bar, advanced filtering, and offline viewing. Its latest version offers offline movie and trailer saving. In addition, the app supports multiple platforms and subtitles can be changed according to speed and language. It is compatible with all video formats. It's easy to use and allows users to download movies without any problem.
blaktro
I just found out B9 tv has only 100mbps ethernet, even tho it should give me at least 80mbps download speed rate. My download speeds are between 15-20mbps and I dont know why.
I pluged in laptop with 100mpbs ethernet network card in the same UTP cable, and it goes to 80mbps at speedtest.net. (my ISP speeds are 300mbps download, 25 upload)
I use PLEX and the speed does matter.
Can you tell me what may be the problem, what can I make to solve it?
