Our app has a MSE player that just hangs forever when trying to play Clear content after DRM content (widevine).
Every other scenario works:
- Clear after clear
- DRM after DRM
- DRM after clear
This is only happening in webos 4 (LM18A), any clue?
    • By mean2
    • By Bhanu Kumar
    • By atcronin
    • By PVD
