Diagnose FPS(refresh) and resolution of output
By Lesbo
By ato53
I have a new C4 TV.
Thanks for the follow-up
By starwoodtech
By dolbnya
By Aventiled
Hey
I have an OLED C3 evo
A Pioneer amplifier is connected to the optical output.
I want to connect Bluetooth headphones and use them at the same time as the amplifier.
The thing is, I haven't seen such an option on TV. It is possible to play simultaneously with the Bluetooth headphones and the internal speakers on the TV.
There is no option for Bluetooth and the optical port at the same time.
Am I missing something here?
Dani
Kai Hendry
Hi there,
How do I see the resolution / refresh rate of what is being outputed on my LG TV from my console?
Thank you in advance!!
