Dynamic contrast does not work after update 05.10.15
By mean2
By OliverRC
By Ajothen
By Horniak
Wins Beans
Hello. There is a 43um7600plb TV (2019) . After the WebOS updating to 05.10.15, the dynamic contrast function does not work. When switching modes (off, low, medium, high), the contrast does not change. Resetting the settings didn't help.
