How do I get 5.1 out of this stupid TV!!!
Bought a oled65g16la worse thing I ever did, how do you put a normal size plug behind a 19mm thick TV? answer is you can't!!
I have a Sonos system, works fine on all other TV's, but I can only get Stereo out of it and not 5.1, it's connected via HDMI, supports ARC, I have gone to setting and tried everything, anyone have any idea's?
Great picture, rubbish TV
3 answers to this question
I've had a similar problem when playing a DVD that defaults to 5.1.
I solved it by going to Settings, All Settings, Sound, Sound Out, PCM (not Auto)
Hope this helps!
Some info.
OLED55P TV   Marantz SR5500 receiver.
A call to support revealed sound out using  "Internal Speaker and Optical" option  will  only be stereo.
Sound out set as  "Optical" only,  passes 5.1 Dolby,  Atmos and DTS  through to  the AMP without fault.  You can use the Dolby apps in the apps library to test it out.  Very impressive.
I suspect Digital Out will do the same. I don't have a cable to test.  It needs to meet a digital standard.
Try selecting just your SONOS  HDMI output as  ARC as your sound out and dont split it with the internal speaker.  I cant test this as I don't have HDMI input on my Amp but given how the optical  output works it may work the same for ARC.
Good Luck.
    • By Private user EU
      I purchase several months ago a LG smart tv.
      I really care about privacy.
      I dont trust voice recording, and sending private information ouside E.U.
      Now my Stupid "Smart tv" keep boring me to accept something i will not accept.
      If LG require is clients to accept the user aggrement, no problem, but is has to be, before i purchase the TV.
      LG cant change the rules after the purchase, several month later.
      I just want a TV.
      Dont want to sent my private information, to who know where...
      Now i make my tv, dont ask me every minute to agree the user agreement, when i dont want to agree?
      Dont find the option dont want!
    • By Dec913
      How do you stop the pointless stupid music that plays if there is not a device connected to the selected input, or it’s not switched in yet. Even if I turn the device on before the tv you still get a burst of this pointless noisy music
