Stream/cast my movies from Ubuntu 21.04 to LG Smart TV 55UM7100PLB WebOS 4.9.x
By Will M
By Lesbo
By Rex G
By Mogens
Kind regards
Mogens
Jjufyu23
I'd like to easily stream/cast some movie files (.mkv, .mp4 etc...) on my Ubuntu 21.04 PC to a LG Smart TV having WebOS 4.9.x.
Both TV and PC are connected on the same LAN network via ethernet cable!
My router does not provide any UPnP feature!
I tried to use (with no success):
- Kodi - enabled UPnP/DLNA and shared my library, then right clicked on a movie and ran "Play using", selected "TV" but I was not able to see anything on my LG TV (i went to Movies and Photos and did not see any remote device or other stuff) (does this method nroamlly work? Maybe there is something wrong with my Kodi / Router configuration? What screen do I have to access on the LG TV to see the DLNA devices?)
- Integrated Ubuntu "Media Sharing" (see https://ubuntuhandbook.org/index.php/2020/04/home-media-server-ubuntu-2004/) - same as above, I could not see any device from the TV when this option is enabled
- VLC UPnP feature - same as above
What options do I have, without buying any additional device like Chromecast, Raspberry PI etc...?
