Hotstar+Disney showing playback error
Hi. There seems to be a problem with the hostar+Disney app. It’s shows a play back error. I tried everything from restarting tv to uninstalling and reinstalling the app.  Still it shows PI 6002 NAS ERROR
    • By mr.porter
      Hello
      Question about new LG WebOS tv's, anyone noticed when pausing live TV ( live playback) on Webos 5.3 ( GX ) that recording is reset when changing channels.
      Meaning if you have paused tv and then changed the channel the playback recording is lost / reset to 0 minutes.
      I've have two LG tv's before the GX that didn't do this current this have one.
    • By Marko00
      only with cancel button.
      How to fix it?
    • By leader6234
      Hey guys !!!
      Thanks in advance !!!
    • By Muser
    • By Danster75
      Hi all,
      I'm Danny and have a problem with my LG OLED65C8;
      since a few months when playing movies, either from my Syno NAS or just plain USB, subtitles are being displayed double (over or above eachother) or are displayed for sometimes minutes after the sentence's been spoken. The videofiles haven't got any hardcoded subs but either subs included in the mkv container or as separate srt of ssa file. Disabling subs removes the display of subs, enabling subs results in double or persistent subs.
      Subtitles have been disabled in the accessability menu, factory reset did not help.
      I searched but as far as I can see this problem has not been discussed yet, also googled and never came across this problem. Perhaps someone here can help?
      Kind regards, Danny
      SOLUTION, for me at least:
      I used ColorControl to reboot the TV. It's weird that a factory reset did not work but a simple reboot did.
