    • By Raicho
      Hi, so the spotify app doesn't appear on LG TV LF630V with Bulgaria selected in the settings.
    • By Luka Pantsulaia
    • By leodavid
      I've recently purchased a WebOS TV UK6400PVC and magic remote came with it. The software version is 4.10.30.
      The buttons work fine but for some reason, I can't get the cursor to appear on screen.
      Appreciate the help. Thanks
    • By whaleandtuna
      Please Help. I have LG qned tv with webOS 23
      1) What I did: with svc remote -> in start -> 0413 and all, area option was changed.
      I was trying many numbers to find the code for KR (which didn't work).
      2) What I wanted : change area option from CA -> KR (widely known area codes do not work)
      Original code: CAD 22411
      3) Problem: Once I put a number between 19461 ~ 19489, Language&Country is set to EU and would not change the country with the other numbers.
      Area option: 19461 ~ 19489 Continent index: 5 ~ 33 Language & Country: EU
      Now I put 22411 to change it back to original region, but the country would not change from EU to CA, the area option is back to 19461.
      If anyone is trying the area option numbers, don't put any number between them.
      If any one knows how to resolve, please help me to escape from EU.. I am so desperate.
      FYI just in case
      hk 17930
      hk 17935
      co 17560
      ph 15670
      cn 17816
      ja 17211
      aj 17083
      tw 17432
      pa 17679
      hn 18618
      ca 18362
      mx 18456
      hn 18584
      br 18789
      cl 18876
      pe 19033
      ar 19123
      ec 19251
      jp 19345
    • By Ali Abbasi
      Hi: Im from Pakistan i have 55UQ91006lc  i dont understand why region limitations in it. many apps not working many apps are not available even google assistant not working region not support error.this is not good in lg tvs please give me unlock region limitation solution so i can enjoy with your products and i also suggest to others but at this point it is cant useable  or we move to android tv like sony this is to bad you are not supporting your customers not providing good servicing.
